12-01-2024 12:42 PM
I'm currently in the UAE and my sim card shows "no service".
How can I access technical support (live chat or email ideally)?
I am on iOS 17.1.2, iPhone 13. I've tried without success:
Has anyone got a clue how to fix this issue? or if I need help from tech support to look into my account?
12-01-2024 01:49 PM
@user5000 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
12-01-2024 03:40 PM
@user5000 wrote:
- in Settings > Mobile Service > toggle on/off "Data Roaming" (it's activated on my line as it's worked a couple of months ago, from the same location)
Data roaming is not an account facility, it's a device-level function that allows your phone to use mobile data whilst roaming.
Roaming itself is an account-level setting that enables access to foreign networks, and cannot be set from your phone alone.
Having said that, if you have used your current SIM on foreign networks previously, there is no reason for it not to connect now - unless you have explicitly requested it removed at some stage.
15-01-2024 08:16 AM
Hello @XRaySpeX and @bristolian ,
Thanks for taking the time to respond. I am on contract and roaming was activated on my contract. It worked back in December, then I left the country and came back again and roaming stopped working for some reason. I turned off/on the line and my phone as well in multiple combinations and it didn't want to catch the signal for some reason. However, I did that over multiple days and it now works, without EE's intervention. I get the feeling that this may happen again. If it does, how can I reach support online instead of through a phone call?
Thanks for your help.
15-01-2024 08:19 AM
Hi @user5000,
You can chat with Customer Care online via the help section of the EE app.
Hope this helps. 🙂
