20-10-2023 04:41 PM
I have been with EE and orange for over 25yrs and everytime I go abroad I get ripped off and can't even make calls and texts .my daughter is on O2 and has no probs at all
20-10-2023 04:51 PM
@jonnyraptor : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
20-10-2023 04:58 PM
Contract always have been ,I received a text from EE when I landed saying select a data bundle I selected one for £35 which lasted less than 24hrs and have had no reception now since Saturday now I see on EE website you can apparently pay just 25 to use your plan from home. Why wasn't this clearer and why do I have no reception?
20-10-2023 05:05 PM
What another user can do abroad has little bearing on troubleshooting your issue.
If you received a text message when you first landed abroad, then your phone had a connection to a local network thus proving roaming was active. Try toggling flight mode or manually selecting an alternative local network as there is clearly a problem with the one you're currently connected to.
Your billing add-ons are a separate issue.
20-10-2023 05:10 PM
Where abroad?
