08-01-2023 11:08 AM
Hi there, I’m currently in Portugal but I need to make a call to a landline in London, but I haven’t been able to. May you please help?
08-01-2023 11:37 AM
Hi @robbarreto
Thanks for coming here.
Can you call other UK landlines and mobiles?
Speak soon.
08-01-2023 11:38 AM - last edited on 08-01-2023 11:43 AM by Leanne_T
Thank you for your reply.
No I can only message atm.
[mod edit: please don't post personal details on the forum]
08-01-2023 11:43 AM
Hi @robbarreto
Can you receive calls and texts?
Do you have signal?
Also, what happens if you try and make a call?
08-01-2023 11:54 AM
Hi Leanne
Yes I can and signal is also fine.
The problem is only on calling UK.
08-01-2023 12:34 PM
Thanks @robbarreto
Can you try manually connecting to another network in the phone settings, to see if you can make calls?
08-01-2023 04:48 PM
There's two account-level settings needed to use EE phones outside the UK
1: International roaming - enables your phone to connect to foreign networks
2: Call abroad & premium rate. It sounds like this may not be enabled.
Manually connecting to an alternative local network, will be the test.
