06-05-2024 07:55 AM
Not just you, I’ve been noticing for months how bad the signal is. Previously 4g/5g signal strength was great all over Glasgow. Now standing in the city centre I struggle to get a signal anywhere.
and it’s not just Glasgow, generally I’m all out n about for work and find poor signal is a constant issue.
for reference I’m using iPhone 15 pro max.
06-05-2024 08:22 AM - edited 06-05-2024 08:23 AM
Hi @Jiggyg
Do you know if any other EE users have the same problem in the areas you have experienced signal problems?
If this happens in multiple areas, are you able to try the SIM card in a different device to see if the same happens?
Leanne 🙂
