10-06-2023 02:35 AM
Some providers such as smarty limit the phones which can use 5g. Could this be due to some limitations of part of the devices? On my pixel 5, the speeds on my unlimited essentials are with 5g showing comparable to 4g when it was novelty.i.e. Between 1mbps ofr less to 15 but not reliable enough for Ms teams with video and screen sharing.
11-06-2023 08:31 AM
Hello @T52.
Welcome to the community.
The speeds which you receive using 5G are these the same in any location you visit which has 5G in the area?
Katie
11-06-2023 09:27 AM
@T52 Your not restricted because of the device type you use. You can be restricted because of distance to the mast the number of users connected to that mast and what ever is between you and that mast and my favourite of all the weather.
11-06-2023 10:30 AM
Hi Katie
Thank you. Yes, I'm that the highest the lowest dl, i. e. 24 Mbps and 0.01 outliers are recoded at my home, and the majority are between 4 and 8, so they are the lower part of 4g, but what worries is that there are blackouts.
Overall, much worse than those I had on a 4g phone for some two months in April and May 2022, but this same 4g phone as I inserted the SIM card now showed the majority around 1 Mbps. Such stats are tricky when in small numbers but the experience is bad.
Could it be that the no frills plan the agent or system (sounds Matrix) put me instead of the agreed unlimited essentials could be the reason?
This is going to be put right after a month's cycle, so I can not tell now.
11-06-2023 10:32 AM
Okay, good to know. So I won't try buying a newer phone.
11-06-2023 10:36 AM
Thanks for replies so far.
The mast is half a mile away.
Anyone know if there are possible technical reasons why smarty restrict 5g to pixels 6 up although models 3 through 5 are 5g as well?
