01-11-2023 03:50 PM
I have an old Doro "dumb" mobile, I've had it for at least 10 years but can't remember the model number. It does everything I want to do: send and receive texts, make and receive phone calls, take occasional photos, listen to FM Radio. It is definitely 3G. It is (or was) my understanding that after 3G switch off it will still work for the funtions I've outlined, though this will be via 2G. Is that correct? Someone from EE has said I'll need to upgrade it by putting in a 4G SIM but is that actually going to work? What would be the point if the phone itself can't access the internet (and I don't want it to anyway). It's currently a PAYG phone but I wouldn't expect that to make any difference. I'm seeing conflicting advice and opinions on the internet about the 3G switch off which is why I'm posting here. If eventually I have to replace it with a newer 4G capable Doro I don't mind - I just don't have much use for a Smart phone. I'm not IT phobic but only access the internet at home on a PC! Many thanks in advance.
01-11-2023 03:57 PM - edited 01-11-2023 04:00 PM
If you just want to make Calls and Text's (SMS) and not bother with Internet Data then you don't need to do or change anything, your Phone and Sim Card will just carry on working on 2G Only after the 3G has been switched off.
You will need to address this whole issue again when it comes to the 2G Switch Off but that not for quiet a while yet.
By the way you can access the Internet on 2G, its just painfully slow compared to modern 4G/5G Technology.
01-11-2023 04:02 PM
Thanks for this, it's put my mind at rest - for now at any rate. I'll worry about the 2G switch off later then!
01-11-2023 06:09 PM
Doesn't FM Radio use data or does it incorporate a radio tuner?
02-11-2023 10:48 AM
It accesses FM Radio via a menu option, so I think the phone has some sort of built in receiver and I just have to plug in some headphones. I don't think this would be data use, but please correct me if I'm wrong. (Your previous advice about how to sort out another PAYG which had gone into hibernation proved very useful!)
02-11-2023 10:53 AM
Phones that had FM radios had an in-built tuner and used the headphone wires as an antenna.
It's only recent phones with radio apps that use streaming methods.
02-11-2023 11:00 AM
Thanks for this, you've confirmed what I thought was the case, very helpful!
