25-10-2023 10:13 PM
Don’t know why but there is absolutely no service and I mean completely dead service in Coulsdon. Been the issue for over 2 hours now. Not able to receive, send call, use data and text.
a complete shutdown.
anyone help ??
25-10-2023 10:23 PM
Hi @anuvc798
Have you tried restarting your device.
Have you checked EE network status checker:
https://coverage.ee.co.uk/coverage/ee
25-10-2023 10:28 PM
I did try restarting my device, checked the network status checker and more but to no avail.
25-10-2023 10:29 PM
Hi @anuvc798
You can report issues on the checker.
25-10-2023 10:35 PM
Exact thing has happened to me in Scotland
26-10-2023 08:13 AM
The status checker serves 2 purposes.
"Check coverage" - what is the predicted service in this area?
"Check status" - are there any known issues here? Subsequent options for "report a problem" or "keep me posted" depending.
Which options have you followed?
26-10-2023 02:51 PM
Hi I checked the status and it says no problem even though it has affected 2 of my devices which both run on EE sim respectively, its been the issue from 7.00pm yesterday
26-10-2023 02:59 PM
Thanks for getting back to us @BOSSCHAD.
You should be able to report the issue using the network checker.
Please ensure you are selecting status then the option to report a problem will appear.
Katie
26-10-2023 03:05 PM
I did that yesterday itself
26-10-2023 03:30 PM
Did you get a reference @BOSSCHAD?
Katie
