26-09-2023 06:50 PM
Hi, I've been having some problems with my 5G EE Hub over the last couple of weeks. I've had the hub in place for two years, by this point I believe.
I'll be playing a game perfectly fine, connection has no issues, but every few minutes or so, there's a massive lag spike that occurs. It's not exact on how often it happens, but it's frequent enough that my experience becomes frustrating. It happens regardless of game (World of Warcraft, Raft, Halo Infinite), and even results in situations where I'm trying to watch movies and still getting frequent spikes with buffering.
My PC is connected via Ethernet Cable, so it's not a problem with Wifi. I've not noticed any lag spikes on Switch. Is there anything that might be causing this sort of situation on the network at all? Or is my hub just falling into the trap of planned obsolescence?
27-09-2023 07:50 AM
Hi @Bodehn
Welcome to the community.
Have you checked your postcode to see if there are any maintenance works in your area? Pop your postcode into our coverage checker and hit 'check status'.
27-09-2023 10:20 AM
Hi @Christopher_G,
Unfortunately, having just checked the status, there are no issues within the area. No maintenance, either.
27-09-2023 10:32 AM
OK, thanks @Bodehn
Have you spoken to our technical support team about this?
28-09-2023 12:47 AM
@Christopher_G, I tried that earlier today. The end result seemed to be either to try swapping the sim to a new device to see whether it's the device or the sim that's causing the problem, but I don't have another compatible device available. The other usual suspects we attempted were a reboot of the device, a reset of the device, and unfortunately nothing worked. I did learn that it's a 4G hub, not a 5G one, however.
28-09-2023 08:46 AM
28-09-2023 11:17 AM
Hi @James_B,
They did. They checked to see if the masts were functioning (they were), performed a network test (everything good on their end). The only thing they said might be the cause was recent maintenance, but there hadn't been any performed in the last six days, so that shouldn't have been causing the issues.
28-09-2023 12:14 PM
Hi @Bodehn,
I'd recommend getting back in touch with Technical Support to see if there is any further steps they can take to escalate this issue for you.
