25-01-2024 03:08 AM
I don't use much data - I have 3GB per month and it always lasts no problem. Three days after the refresh I got the 80% warning - twenty minutes later, yes twenty minutes - the 100%. What's that about? Anybody have similar?
25-01-2024 08:28 AM
Hi @johnAKAmark
Thanks for coming here.
What device are you using?
Do you use WiFi when at home and for app/software updates?
25-01-2024 02:17 PM
iphone 12 mini - software and app updates on wifi only.
25-01-2024 02:55 PM
Thanks @johnAKAmark
Has your WiFi connection been OK?
If you go to Settings > Mobile Data and scroll to the bottom, is 'Wi-Fi Assist' enabled?
25-01-2024 05:22 PM
Wifi all good - Wi-Fi. Assist not enabled - I literally lost the remaining 20% of my data in under half an hour while not using the phone at all. I have purchased a 2GB add-on, not happy.
25-01-2024 05:30 PM
Hi @johnAKAmark,
Have you checked your mobile data usage by app to see if any particular apps are using more data than you'd expect?
Go to Settings > Mobile data to check.
