07-12-2022 05:59 AM
Hi, I’m currently in Australia and had been using my U.K. mobile phone with a roaming add on without any problems. A few days ago it stopped working and my phone has said “sos only” ever since. I’ve tried the obvious turning my data and phone off and on again but it hasn’t helped. I can’t call EE because I have no access to the network and I can’t log in to my EE account because it sends a verification code via text which I can’t receive without network. I can use WiFi only.
Can anybody make any suggestions please? I’m a female alone with a 3 month old baby and it’s quite unsafe when I’m away from WiFi and no connection.
07-12-2022 07:25 AM
@Alison728 Sounds like the network your connection is with is having issues. If it was working ok and you’ve not changed anything there is no reason it’ll not work now unless there was a local network issue.
07-12-2022 08:28 AM
Hi Alison,
please be aware that calls over wifi are charged at the full international rate when roaming. If you have been doing so you may have incurred sufficient charges to reach your cap on spending. At that point your service would be blocked to prevent any further expense
07-12-2022 08:33 AM
07-12-2022 08:41 AM
Alison, turn off calling over wifi on your phone settings to avoid the charges
07-12-2022 08:44 AM
This information is buried away in the web page linked to the text message sent by Ed when you set up the roaming add on. Searching on the general website for it will not show anything. I think this is a bit misleading and could be construed as underhand to generate revenue
07-12-2022 11:27 AM
Thanks Chris. At first I thought there was an issue with the network somewhere but I haven’t had any connection for days now.
07-12-2022 11:31 AM
Thanks Martin, that’s good to know. But WiFi calling isn’t working anyway. I paid for the roaming add on to use my normal U.K. plan whilst abroad so I shouldn’t have incurred any extra charges.
07-12-2022 12:00 PM
Hi @Alison728
Thanks for coming here.
Can you try manually connecting to a different network in your phone settings?
07-12-2022 12:37 PM
Good idea Leanne. I’ve just tried connecting manually but unfortunately it didn’t work and it still says sos only.
