21-01-2024 09:55 PM
Hello. I've used current plan for 3months but I want to change the plan. Recently I got message from EE that my 50% discount will expire and I can change my plan at ee website. However, while I used my phone, I thought data is too slow than I expect so I just use wifi, and I think current plan is not suitable for me. Can I downgrade my plan???
Moreover, I was thinking to buy 1year plan, but I had to buy 2yrs plan because according to the store they don't offer 1yr plan. But I have to move to another country in 15months. So if it's possible I want to change my plan.
Can I change my plan?? If it is possible where should I ask?
Thank u.
21-01-2024 09:59 PM
You can't downgrade to a cheaper plan mid-term, but only in your upgrade window from 45 days before end of term.
