23-03-2022 02:55 PM
I have bought a 4GEE Mini to test the broadband data speed in my area, and using this
device i can get up to 40-45MB download speed with the device outside. I then put the
SIM into a TP-Link MR6400 Router and tested it at exactly the same location but i get less than half the download speed. Is the EE data speed capped if the Sim is in a non EE device?
26-03-2022 02:36 PM
@itretail your 4GEE MIni EE71 is Cat 7.
23-03-2022 03:09 PM - edited 23-03-2022 03:09 PM
No.
More likely to do with 4G LTE Router spec Category and whether your using 2.4 or 5ghz WiFi on the Router.
From memory your TP Link Router is only LTE CAT4, can't remember if it does 5Ghz WiFi, but a modern, more up to date 4GEE Router will be a better and speedier spec.
23-03-2022 04:25 PM
Not sure what you mean by "only CAT 4" is there a better standard, i have searched
for the latest "best" 4G routers and they are all CAT 4.
23-03-2022 06:11 PM
Most decent high end 4G Routers are around Cat18, Cat 20 or more Cat4 is quiet an old spec by comparison.
23-03-2022 06:29 PM
Any idea what spec the 4GEE Home Router 3 is?
24-03-2022 04:16 PM - edited 24-03-2022 04:19 PM
Your Router, no I don't but if you can post up the full model number, probably on the Router Label or box, I will try and check, as EE are a bit shy on their LTE Router specs
If I was to hazard a guess though, I would go with Cat7 or Cat12.
The LTE Categories are a bit confusing, but as a rough guide, things started to get interesting at Cat6, although most Devices went for Cat7 over 6, as that's when LTE Advanced kicked in, also known as LTE A, LTE+, LTE CA and 4G+, Meaning max DL Speed Spec of around 600mbs.
Cat12 onwards was the next leap, with additional CA and some more Multi Mimo trickery.
Followed by Cat16 (Gigabit) where 256QAM was introduced meaning with the above trickery and the wind blowing in the right direction Max DL Speeds of just a tad under 1000gbs.
Cat18, 20 and 22 took us over the 1Gbs DL potential a few years back but remember these are Technical Specs and the Device needs to be talking to a correctly configured Mast to get anywhere close to the theoretical Specs and Speeds.
24-03-2022 04:26 PM
The 4gEE Mini which i have is EE71-2BEBGB3
26-03-2022 02:36 PM
