19-12-2022 09:52 AM
I have a £2 per day addon on my contract, for roaming B-road how do I activate it?
there is currently a £zero spend cap on my account is this anything to do with it.
19-12-2022 10:15 AM
Hi @Neilc2
Thanks for coming here.
Are you abroad at the moment?
If so, did you text ROAMING to 150 before travelling abroad?
19-12-2022 06:30 PM
19-12-2022 06:35 PM - edited 19-12-2022 06:36 PM
@Neilc2 Did you activate roaming on your EE account before you left the UK ? The £2 roaming add on it’s just a free add on and it means you’ll be charged £2 per day to use your allowances.( the add on is only free to have not use ) But if you purchase the £10 roam further add on you’ll not be charged the £2 per day daily usage charge. It all comes down to how long are you out of the UK for. If it’s a couple of days the £10 add on is going to cost you more and just using the £2 daily charge will be cheaper.
But you need roaming enabled on your account first as add ons don’t enable roaming there just add ons to keep costs down when abroad.
