Ps5 wont connect to my ee mini hub
Bobbykerrie1
20 REPLIES 20
Does your EE mobile router's SSID appear under that "Networks Found" & have you connected to it?
Press that "OK" & let's see what's behind it.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
I have the same problem and the WiFi name ssid shows up in ps5 wifi settings but won't connect as it say the above message in picture posted. Please help as this is why I bought the wifi router
James_B
Can you successfully connect other devices to your router @Potterp81?
Yes, I use it on my laptop aswell no problems at all
Sent from my Galaxy
James_B
Hi @Potterp81,
If you're able to connect to other devices successfully, I'd recommend reaching out to Sony Support.
So why does Sony suggest my service provider is blocking the service, I can see this going round in circles.
Sent from my Galaxy
Christopher_G
I'm not sure why that would be, @Potterp81
Have a chat with our technical team. They'll be able to check to see if everything is OK from our side.
I am having the same issue as above, it was working fine and I only used it for my PS5 and then all of a sudden it won’t connect, the internet works on other devices but just not my PS5 I need help
Leanne_T
Hi @Reg10
Thanks for coming here.
Does the PS5 connect to the router but has no internet connection?
Have you restarted the router and PS5?
