09-04-2024 03:00 PM
I use lots of EE data sims with my business and over the past 6 months most of my EE sims will not work in my 5g routers.
They all work fine in a 4g router.
I have tried Robustel, Viprinet, Teltonica and Celerway 5G routers and they all fail to recognise the sim. I have replaced the sims and it make no difference. I have spoken to other customers who use these types of routers and they are also seeing this problem with some EE sims. I have a few sims that will work in a 5g router and when I compare the tariff they are on to a sim that is not working, there is no difference. Anyone else seen this issue and been able to resolve the issue?
09-04-2024 03:36 PM - edited 09-04-2024 03:40 PM
Have you tried a more common mainline mobile router, like TP-Link, DrayTek, D-Link, NetGear?
09-04-2024 05:30 PM
No I have not and I don't think I should need to.
I have 4 EE sims all on the same data plan and they connect on the Robustel, Viprinet, Teltonica and Celerway 5G routers
I have another 46 EE sims all on the same data plan as above and they do not work in these routers. The symtoms are that the modem cannot read the ICCID and so never gets any further to connect.
All of the SIMS connect on 4g
The modem chip that is used in all these devices is the QUECTEL 5g
I have spoken to different companies using the same equipment and they are also seeing the same problem. So this is very strange.
11-04-2024 10:25 AM
This is still a major problem and currently I only have a few sims that will work with 5g modems. I'm having to revert to a different carrier like the three network becuase they just work. Any advice on how this can be escalated?
11-04-2024 11:25 AM
Hi @Dom83
To get this looked into, please get in touch with our business team who will have access to the accounts and run troubleshooting to help you get this resolved.
