03-05-2024 11:14 AM
Hi - I have a 5G Wifi box from the previous generation with the ethernet port. Just wondering if the new version with only USB-C is able to provide an ethernet connection via a dongle?
Cheers all.
03-05-2024 11:24 AM - edited 03-05-2024 11:25 AM
What do you mean by "via a dongle"? The USB connection will provide a quasi-Ethernet connection to whatever it's connected to.
03-05-2024 11:27 AM
I need to connect a device via ethernet (and only ethernet), so curious as to if the USB-C with an adapter would work for this.
03-05-2024 11:29 AM
As I said it should. What's the device?
03-05-2024 11:31 AM
Ah great thank you. It's a bit of broadcast equipment that's been retrofitted with an IP card to go from ISDN to IP audio stream.
