31-07-2023 01:01 PM
I’m wanting to change my network.The amount I pay is £108 every month and I need something cheaper.
31-07-2023 01:26 PM
Hello @Alicia27 ,
Welcome to the community,
You will have to pay out the remaining of your contract minus 4% if you are not at the end of your minimum term.
You will need to get a PAC code if you want to keep your number, which you will need to give to your new provider, once you have the SIM card from them.
I suggest you ring Ee customer service first and speak to them and see what they can do for you.
