Wifi 6
l1feways
SH2 was giving me 300mbps tops on my BT 500mbps. Looked into buying a router but the majority looked like massive upside down spiders , and expensive..solution, bought a EEwifi smart hub plus from a well known auction site for £50. Wow literally plug and play and getting the full 500 over wifi next to the box and no lower then 400 elsewhere. Smart hub plus really is next level and a simple solution to the now near pre historic SH2
Northerner
Hi @l1feways
Pleased for you well done.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
