14-12-2023 04:36 PM
Hi
I have purchased digital phones to link to my EE smart hub plus. The work fine, but I would also like to use a desktop phone, mainly so I can use a headset. Does anyone know if you can use VOIP phones with the hub.
As an alternative is there anyway to use a headset with the existing set up.
14-12-2023 07:14 PM
Hi @heelisp a desktop phone won't work with the Digital home phone service. The phones need to be connected via the green socket on the back of the Hub or DECT.
Neil
14-12-2023 05:10 PM
You can use any DECT phone system. BT's version of VoIP, Digital Voice, is just how the signal is transmitted over the Net.
14-12-2023 07:14 PM
Neil
