31-03-2024 03:59 PM
Can anyone help me at all - bit of a novice when it comes to these things.
I am trying to connect to a VPN called OpenVpn and I Have been provided a profile to load in - which I managed to get to work.
When I attempt to connect I get the following "log"
2024-03-31 15:57:53.915550 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2024-03-31 15:57:53.915752 TLS Error: TLS handshake failed
2024-03-31 15:57:53.917831 SIGUSR1[soft,tls-error] received, process restarting
2024-03-31 15:57:53.918079 MANAGEMENT: >STATE:1711897073,RECONNECTING,tls-error,,,,,
2024-03-31 15:57:53.938601 MANAGEMENT: CMD 'hold release'
2024-03-31 15:57:53.938731 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-03-31 15:57:53.938851 Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
2024-03-31 15:57:53.938898 Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
2024-03-31 15:57:53.938917 Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
2024-03-31 15:57:53.938935 Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
2024-03-31 15:57:53.939091 TCP/UDP: Preserving recently used remote address: [AF_INET]85.203.33.91:443
2024-03-31 15:57:53.939178 Socket Buffers: R=[786896->786896] S=[9216->9216]
2024-03-31 15:57:53.939195 UDP link local: (not bound)
2024-03-31 15:57:53.939209 UDP link remote: [AF_INET]85.203.33.91:443
2024-03-31 15:57:53.939234 MANAGEMENT: >STATE:1711897073,WAIT,,,,,,
2024-03-31 15:57:53.941175 MANAGEMENT: CMD 'hold release'
It look likes whatever the profile does seems to work but I can't establish a connection. Not sure if there are some settings on the router I need to update / change?
31-03-2024 06:20 PM
Hi @jre111s
Are you on mobile or fixed line broadband.
Who is your VPN provider.
