09-01-2024 06:24 PM
I have just switched from BTEE to EE Broadband. Since the switch i can't change WiFi Controls in the EE App. I've had tried resetting, reinstalling and all the advice in other threads on here.
Is there a step in the setup that's not worked correctly or something?
Mr K
09-01-2024 08:45 PM
Hi @Kinsleyandco,
Thanks for taking the time to join the Community.
I am sorry that it isn't working for you. We'll need to take a look into this and help.
I'll send you a private message.
Thank you
DanielS
