28-06-2022 09:52 AM
We recently had very frequent drop outs of our internet so contacted EE, they did the following:
Found a problem on the line which an engineer has supposedly fixed
Sent a brand new more up to date router.
Drop outs had gone for a few days up until just now where it cut out for approx 1 minute. The router log file at time of drop out shows this:
09:44:29 | 28 Jun. Receive a DHCP request | ||||||
09:44:28 | 28 Jun. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT | ||||||
09:44:27 | 28 Jun. WAN Sensing Auto sensing Running | ||||||
09:44:27 | 28 Jun. Success - secondary DNS servers | ||||||
09:44:27 | 28 Jun. Success - primary DNS servers | ||||||
09:44:27 | 28 Jun. WAN connection WAN2_INTERNET_PTM connected | ||||||
09:44:27 | 28 Jun. PPP: IPCP up | ||||||
09:44:27 | 28 Jun. PPP IPCP Receive Configuration ACK | ||||||
09:44:27 | 28 Jun. PPP IPCP Send Configuration Request | ||||||
09:44:27 | 28 Jun. PPP IPCP Receive Configuration NAK | ||||||
09:44:26 | 28 Jun. PPP IPCP Send Configuration ACK | ||||||
09:44:26 | 28 Jun. PPP IPCP Receive Configuration Request | ||||||
09:44:26 | 28 Jun. PPP IPV6CP Send Configuration Request | ||||||
09:44:26 | 28 Jun. PPP IPCP Send Configuration Request | ||||||
09:44:26 | 28 Jun. PPP: CHAP authentication succeeded | ||||||
09:44:26 | 28 Jun. PPP CHAP Receive success : authentication successful | ||||||
09:44:26 | 28 Jun. PPP CHAP Receive Challenge | ||||||
09:44:26 | 28 Jun. PPP: LCP up | ||||||
09:44:26 | 28 Jun. PPP LCP Receive Configuration ACK | ||||||
09:44:26 | 28 Jun. PPP LCP Send Configuration ACK | ||||||
09:44:26 | 28 Jun. PPP LCP Receive Configuration Request | ||||||
09:44:26 | 28 Jun. PPP LCP Send Configuration Request | ||||||
09:44:24 | 28 Jun. 2.4G Client disassociate from c0:b5:d7:03:9e:55 (IP=192.168.1.114) RSSI=0 | Rate=0Mbps | |||||
09:44:23 | 28 Jun. PPP: Received PADS | ||||||
09:44:23 | 28 Jun. PPP: Sending PADR | ||||||
09:44:23 | 28 Jun. PPP: Received PADO | ||||||
09:44:23 | 28 Jun. PPP: Sending PADI | ||||||
09:44:18 | 28 Jun. PPP: Sending PADI | ||||||
09:44:13 | 28 Jun. PPP: Sending PADI | ||||||
09:44:08 | 28 Jun. PPP: Sending PADI | ||||||
09:44:03 | 28 Jun. PPP: Sending PADI | ||||||
09:43:58 | 28 Jun. PPP: Sending PADI | ||||||
09:43:53 | 28 Jun. PPP: Sending PADI | ||||||
09:43:52 | 28 Jun. Multicast stream started by client 192.168.1.253 | ||||||
09:43:52 | 28 Jun. Multicast event client join group:224.0.1.60 client:192.168.1.253 | ||||||
09:43:52 | 28 Jun. Multicast stream request. client:192.168.1.253 group:224.0.1.60 | ||||||
09:43:48 | 28 Jun. PPP: Sending PADI | ||||||
09:43:43 | 28 Jun. PPP: Sending PADI | ||||||
09:43:39 | 28 Jun. 2.4G Client associate from c0:b5:d7:03:9e:55 (IP=192.168.1.114) RSSI=-56 | Rate=72Mbps | host DESKTOP-FB92O2M | ||||
09:43:38 | 28 Jun. 2.4G Client associate from c0:b5:d7:03:9e:55 (IP=192.168.1.114) RSSI=-57 | Rate=0Mbps | host DESKTOP-FB92O2M | ||||
09:43:38 | 28 Jun. Receive a DHCP request | ||||||
09:43:38 | 28 Jun. DHCP device Connected: 192.168.1.114 | c0:b5:d7:03:9e:55 | DESKTOP-FB92O2M | ||||
09:43:38 | 28 Jun. PPP: Sending PADI | ||||||
09:43:38 | 28 Jun. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT | ||||||
09:43:34 | 28 Jun. 5G Client disassociate from c0:b5:d7:03:9e:55 (IP=192.168.1.114) RSSI=0 | Rate=0Mbps |
28-06-2022 11:53 AM
@Boring25 hi, is it just one drop, if so I would not worry about it.
Posting raw log files of a single event does not help, it would be better to use a filter that can then show how often the drops happen.
If you are getting more than a single drop, get back to the Broadband care team who may decide you need another engineer visit.
28-06-2022 12:52 PM
There isn't even 1 "Down" or "drop out" in that extract of the log. What colours are the light sequence when it happens?
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
28-06-2022 01:44 PM
It has happened 3 times today for 1-2 minutes each time
28-06-2022 03:11 PM
This is a list of your EE Smart Hub settings and current statistics.
Software variant:-
28-06-2022 03:12 PM
62.2 | 43 | 13.9 | 8.6 | 35 | Available | Available | -- |
61.1 | 40 | 13.6 | 8 | 34 | Available | Available | -- |
330 | 50 | -- | Available | -- |
Up to 2 | -- | 1 to 3 | Available | Yes |
Up to 1 | -- | 1 to 3 | Available | -- |
1 | -- | -- | Available | Yes |
1 | -- | -- | Available | -- |
Up to 2 | -- | 1 to 3 | -- | Yes |
Up to 1 | -- | -- | -- | |
Up to 1 | -- | 1 to 3 | -- | Yes |
39.99 |
11.42 |
2022-06-23 |
Available |
Available |
N |
N |
N |
Y |
28-06-2022 03:24 PM - edited 28-06-2022 03:44 PM
You could be getting a sync speed of about 40-50 Meg but are only getting 27 Meg. You were getting 40 Meg 5 days ago which together with your Up speed of 10 Meg suggests you are only on the standard 40 Meg capped Fibre product. I suspect noise on the line is triggering discons and thus causing the DLM to kill your speeds.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
