06-02-2022 07:50 PM
Hi All,
I’ve been an EE broadband customer for around 6 months with the standard EE router.
I generally have good signal strength across the whole house and even as I write this my iPhone XR shows full signal strength… However, regularly while on WiFi I am unable to load websites, Instagram, games or anything else that requires internet access - despite seemingly having full WiFi connection on any device used and the router showing no problems.
I’m not on full fibre broadband, so I can only think that this is a poor connection from EE or a bad router.
Does anyone suffer anything similar or does anyone know how I can improve the service I have?
06-02-2022 07:52 PM
07-02-2022 08:41 PM
07-02-2022 08:42 PM - edited 07-02-2022 08:43 PM
Don’t know if I can upload photos. Got an email?
07-02-2022 09:14 PM
Don't worry they will appear shortly, just need approval.
07-02-2022 09:24 PM
I will leave this for @XRaySpeX to respond in more detail, but it would seem your issue is with wireless reception not the broadband.
07-02-2022 10:27 PM - edited 07-02-2022 10:28 PM
Now my point 2 please? Do it both wired & wireless.
07-02-2022 10:49 PM
Oh sorry lad, I don’t have any devices that can use an Ethernet cable.
no laptops, no computers, just 2 iPhones and an iPad.
07-02-2022 11:58 PM
Then do the speedtest over WiFi. All the better as your WiFi is suspect.
08-02-2022 04:06 PM
