iphone 14 pro upgrade
Kimmy2022
i upgraded from 12 mini to 14 pro however all my apps have transferred over but with the 14 pro you dont need to put a sim card in but its displaying sim card not recognised? should i put my sim card into the new phone
@Kimmy2022   You can use your sim or you can use the eSim.   This is exactly the same as your 12.     Personal I would use your sim and not the eSim if you don’t have 2 phone lines.
