14-11-2022 06:52 PM
Hi, I took my son's phone off him because he was gambling on it - I pay for it! He's got a screen lock on it and I can't get the code. I have changed the apple password online now so he has no access to my account but I want to make use of the phone. How do I get past the pin code. It's not the PUK code, its the initial screen lock code.
14-11-2022 08:50 PM
Hi @Spencer2902
Unless he gives you the code you cannot bypass the pin access.
14-11-2022 09:08 PM
@Spencer2902 , You will have to factory reset if you can, as there is no PIN code access, as @Northerner has written unless your son knows what he did. Hopefully you can factory reset the phone, otherwise not sure what you can do.
14-11-2022 09:26 PM - edited 14-11-2022 09:26 PM
@Spencer2902 You need to put the device in to restore mode or DDU mode and connect it to a pc with iTunes on it . You can then factory reset the device and because it’s on your Apple account you will be able to set this device back up.
What iPhone model is it ? as there is different methods to enter restore/DFU mode.
