07-11-2023 09:56 PM
Hi
I can't seem to get my phone working (and can't make any calls) after using an Esim abroad ... nothing ... can only get wifi.
Does anyone know how to get this working. I need to make an urgent call.
07-11-2023 11:35 PM
Welcome to the EE Community,
Have you tried a manual network search ?
select Vodafone or O2 wait for it to say registration failed then select EE it should then say registration successful.
David
08-11-2023 07:34 AM
Hi David
Thanks for trying to help. How do I do that? The phone comes up with no signal, I don't know where to go for manual.
Thanks V
08-11-2023 07:36 AM
What type of phone are you using @VictoriaPike?
Do you have a physical EE SIM card?
Have you restarted your phone?
08-11-2023 07:56 AM
Hi James
I have a iPhone 14 a physical sim and taken it out, put it back in a few times as well as turning my phone on and off a million times. It just won't connect to the EE signal.
Thanks V
08-11-2023 08:00 AM
Hi @VictoriaPike,
To manually select a network, go to Settings > Mobile Data > Network Selection > Turn off Automatic.
Hope this helps.
08-11-2023 08:30 AM
Not done anything. I will have to go to the EE shop, as no time for this. Thanks for everyone's help. Hopefully EE will be able to fix it fast.
08-11-2023 08:37 AM
Is your EE SIM set as the default voice line @VictoriaPike?
08-11-2023 10:39 AM
Right! They had to replace my sim ... apparently this is a problem with EE when you use a eSim abroad. Not helpful when you return. Anyhow, I had the most wonderful technician at the EE shop in Brixton help me and I am now working.
However it is saying phone from Data or Primary ... I have no clue what this means, as I just used to phone. Any advice please?
08-11-2023 11:48 AM
I'm happy to hear the store team were able to help @VictoriaPike
For more information on the dual SIM features of your iPhone, please see Using Dual SIM with an eSIM – Apple Support (UK).
Hope this helps. 🙂
