04-01-2023 02:02 PM
Battery usage is really high, mainly in the background. Anyone else seeing this?
Approx 33% in last 24 hours.
04-01-2023 04:10 PM
Hi @Jonpmat.
Did you check this under Settings and Battery Usage on your phone?
How long have you had this?
Jon
04-01-2023 04:12 PM - edited 04-01-2023 04:13 PM
Yes, had it installed for about 1 week.
04-01-2023 04:15 PM
URGENT: Remove your mobile no. from this public site. You wanna be spammed?
04-01-2023 04:43 PM
Thanks @Jonpmat.
This shouldn't be happening.
I'd recommend reporting this to our Tech Care team so they can run through troubleshooting steps with you and get this sorted.
Jon
05-01-2023 11:05 AM
I was wondering if anyone else is seeing the same thing?
23-04-2023 10:52 AM
I’ve noticed my battery is dropping a lot quicker now I have cybersecurity and checking usage it is now 19% in 7 hours
23-04-2023 12:34 PM
@Davearran999 That’s because you’re allowing it to run in the background. It’s doing exactly what you’ve allowed it to to. Operate when you’re not even using the device that is exactly what background activity is.
23-04-2023 03:17 PM
Yes, but not use that much battery.
23-04-2023 03:39 PM
Hi @Jonpmat
Thanks for coming here.
Please give us a call on 150, and our tech gurus will run through some troubleshooting with you to get this looked into.
