02-08-2022 07:55 PM
Just switched to EE from BT poor volume on incoming and outgoing calls voices sound muffled had no problems with this before I switched, I have a Galaxy A12
02-08-2022 08:36 PM
Are you using the same phone as you had when with BT Mobile?
Is your phone in a case, and if so is it the same without?
Does it make any difference if you're using a speakerphone, headset or the normal phone speaker?
