19-05-2023 09:16 AM
I have a Samsung S22 Plus. Had it a while but I cannot charge using the c type port via a USB cable as it says that Moisture is detected in the port. The phone is dry (never been wet) I have watched all Youtube videos, cleared USB cache, tried everything I can see or read online but nothing works!
Help appreciated.
AlanB76
19-05-2023 11:17 AM
Hi @AlanB76
Welcome to the community.
Have you tried backing everything up and restoring the phone to factory settings?
19-05-2023 11:54 AM
Hi Christopher
I haven't tried that (yet)
Was trying to resolve without going to those lengths but that's what I might have to try as I cannot resolve this issue.
Alan
19-05-2023 12:06 PM
If it's a software glitch, that should clear it up, @AlanB76
19-05-2023 01:41 PM
@AlanB76 The sweat from your had can cause this to happen. Your other option is to use a wireless charger.
