23-09-2023 09:19 AM
23-09-2023 09:28 AM
Hi @SR63
It is likely you have installed an app which has in turn installed another app which is the problem. Go in to settings - apps and uninstall any app you are not familiar with. Then uninstall any games/junk. You will eventually find the problem app.
23-09-2023 10:48 AM
Hi. Thanks for your reply. I have done all that to the point I've deleted loads. Plus I have no games apps installed. I'm at a loss !
24-09-2023 05:08 PM
@SR63 - Worth resetting both Web browsers (Samsung and Chrome) and blitz the cache and cookies. Maybe do this offline and disconnected from the Internet.
25-09-2023 09:05 AM
Hi. Nothing has worked at all. It's so frustrating. Looks like q factory reset or a smart tutor to see if that solves the problem. I'm so fed up!!!!
