06-05-2024 04:23 PM
My Samsung Galaxy A13 is set to unlock with a fingerprint or with a PIN. If the fingerprint is not being read, and I press the power button, the phone has stopped asking for a PIN and unlocks as soon as the power button is pressed.
08-05-2024 07:43 AM
06-05-2024 06:00 PM
Have you set the extend unlock location, in settings.
Have you checked the finger print and pin is activated.
Have you tried restarting your device.
07-05-2024 06:02 PM
Thanks.
I don't have any extend unlock settings in force and I tried a restart.
I have done a temporary fix by de-registering my fingerprint for unlocking - now the power button takes me to the locked screen and doesn't unlock when I press it. I'd rather have the use of my fingerprint though.
It's only just started doing this; before, if my fingerprint wasn't read, the PIN prompt always came up when I pressed the power button.
08-05-2024 07:43 AM
Have you tried re-registering your fingerprint, @BrianJenking?
08-05-2024 01:27 PM
Thanks James.
That seems to have fixed the issue.
08-05-2024 01:41 PM
No problem, @BrianJenking 🙂
