07-12-2022 10:19 AM
My Google Pixel will continuously turn itself off. Mostly when in my pocket.
Works fine when turned back on.
Any ideas?
07-12-2022 12:18 PM
Thanks for coming here.
Do you have the screen locked when it is in your pocket?
How often does this happen?
Leanne 🙂
07-12-2022 01:24 PM
Yes. Screen locked.
Happens every time in pocket and can happen when left on table over time.
Happens like 20 times a day.
Occasioanlly will turn off when in use. But otherwise works normally.
07-12-2022 01:33 PM
Thanks @markneilly346
Have you tried factory resetting the device?
You will need to back up all your data before trying this.
07-12-2022 03:02 PM
I have tried this.
Same result. I wonder if more of a hardware issue.
Read online that the battery can become loose?
Mark
07-12-2022 03:03 PM
If you give us a call on 150 the team can run through some troubleshooting with you 🙂
