18-09-2022 10:17 AM
My Samsung Galaxy A20e is now three years old. When my contract finished I switched to Sim Only. The phone was working perfectly, but I took up the offer for an MOT two weeks ago, and went to my local store.
Since then the phone performance has deteriorated rapidly. I used to only need to charge it once per day, for two hours on rapid charge.
Now it seems to require charging twice per day, and this isn't always possible. It makes me wish I hadn't bothered. I have also realised that the phone wasn't cleaned, nor was I offered any discount on cases etc.
Disappointing.
18-09-2022 11:07 AM
OK! Thanks for that.
I just thought it seemed quite suspicicious that the deterioration happened immediately after the MOT, when I described how well my phone was working, and I didn't need an upgrade.
Any idea how much a new battery would cost?
18-09-2022 10:45 AM - edited 18-09-2022 10:46 AM
@LizaMac Your battery probably needs to be changed as it’s over 3 years old. Battery are a consumable item the older they get the less charge they can hold. After 2 years I can bet the battery could only hold a low 80 odd percent of its original power at 3 years that’s below 80% and thats when you notice issues with it.
18-09-2022 11:07 AM
18-09-2022 11:32 AM
@LizaMac Sorry I do not know. Prices vary depending on where you take it, and the cheaper is more likely it’s not an official Samsung battery. You really should take to Samsung or to an EE store so it can be sent off to be done.
18-09-2022 04:14 PM
