25-04-2022 10:34 AM
My new phone Oppo S54 5g phone battery doesn't seem to be very good at all my last oppo lasted at least two days without charging this new one I seem to charge it every day. I have turned off the 5g, roaming, and location just using my own internet at home I have yet to try it out and about to see if it lasts over a day at this rate it's not going to last a year nevermind two!! Anyone have any help on this only had it 7 days so far maybe need to contact we about it if there no answers. I have removed many apps to see how this helps but no it didn't.
25-04-2022 11:05 AM
Hi @Dingo22
It is becase your android profile is new and it is not used to your usage. As you use android it learns what apps/services you use and what you don't hibernating unused apps to save power. It's the same with any android phone. Removing apps or closing them down is the worst thing you can do as android manages those services.
Additionally your battery is new and will need to be charged/discharged a few times before it is bedded in.
