17-05-2024 03:25 PM
Hi:
I have just replaced my old mobile with a 4G Galaxy A15 mobile (unlocked) which I bought on Amazon UK. I need to buy a Nano Sim Card for the mobile, using a Pay As You Go sim card. The sim cards advertised on the EE website don’t tell you if they are “Nano Sims” and if these will fit my new phone. (£10 Subscription Pack 8GB Data). Can you advise me on how – and where – to buy the correct sim card. Also, I want to retain my current phone number, how is this done?
Bestwishes, PM.
17-05-2024 04:12 PM
@ARt_ : All SIMs provided by EE are Combi-SIMs with all 3 sizes as push-outs.
Who is your current no. with? If with another network you'll need to get your PAC from them & give it to EE. If it's with EE just buy the SIM you want & then phone CS to move your existing no. to it.
17-05-2024 03:26 PM
Hi:
I have just replaced my old mobile with a 4G Galaxy A15 mobile (unlocked) which I bought on Amazon UK. I need to buy a Nano Sim Card for the mobile, using a Paying As You Go sim card. The sim cards advertised on the EE website don’t tell you if they are “Nano Sims” and if these will fit my new phone. (£10 Subscription Pack 8GB Data). Can you advise me on how – and where – to buy the correct sim card. Also, I want to retain my current phone number, how is this done?
Best wishes, PM.
17-05-2024 03:31 PM
Hi:
Best wishes, PM.
17-05-2024 04:12 PM
20-05-2024 09:51 AM
Thanks for the advice, it is helpful, I am an EE customer; I'll buy the SIM and phone CS as suggested.
Best wishes,
PM.
20-05-2024 09:58 AM
