My mobile can't connect to EE's auto Wifi in public transport
000000002
I'm using EE Sim card for the first time, when I try to connect to WIFI with SIM card verification using the EAP method at the station, the system always prompts me very quickly for a connection timeout, which prevents me from connecting to the WIFI, how do I set it up?
Northerner
Hi @000000002
You set the service up as per the instructions here:
https://ee.co.uk/help/mobile/manage-use/using-phone-features/wifi-on-the-london-underground
It maybe the service isnt working, which is not uncommon.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
Northerner
Hi @000000002
Thank you! I will try at tomorrow!
