19-02-2023 08:03 PM
Watch overheating after 2 minutes using LTE. No issues on Bluetooth, everything else working fine and Checked for updates etc. But tried this on LTE 3 times and has done it every time
19-02-2023 09:02 PM - edited 19-02-2023 09:03 PM
@Pedro80 The device getting hot is the battery consumption. The battery is being depleted so it get hot. Have you tried factory resetting the Watch ? If you do this make sure you keep the data tariff when given the option to do so, you’ll then be able to restore the tariff back on the watch.
24-02-2023 04:25 PM
Thanks have tried this couple of times and watch overheating after 5 minutes
24-02-2023 06:58 PM
OK thanks, @Pedro80
I'd recommend speaking to our Mobile Care team so they can help you with this. Let us know how you get on.
