by Eakinloye
unlocking my mobile phone Huawei P9 lite
Solution
Re: unlocking my mobile phone Huawei P9 lite
If the device had been on your contract for at least 6 months, even if that contract has now been cancelled, you can just apply using the Unlocking your device form as the Pay Monthly option and giving the mobile number that it originally came with. It will first show your new current phone on that number, if any, & ask whether that is the device you want to unlock? If not, you will then have to type in the IMEI of the old phone.
Is it over 6 months old?
Did you buy this device yourself new direct from EE or is it 2nd-hand? The process & costs are different.
@Eakinloye   Click the green wording below to see how to unlock the device and if it’s eligible to be unlocked it will be.  You have to select the correct option or the unlock will fail.
by Eakinloye
I had on contract in the last 2 yrs
by Eakinloye
Contract with EE.... Two years now
Solution
