by gogolino
New Member
unlocking iphone 11 pro
Hi
I've signed new contract with EE - 3 months ago (iphone 11 pro) which has 2 sim cards, I've moved my EE sim to e-SIM with the intention to use my work sim card on the nano-sim slot.
the phone is currently locked and EE is refusing to unlock until month 6.
it seems unfair to me to buy a phone with 2 sim cards and not be able to use the second card due to the sim lock.
I spoke to EE as I am happy to pay deposit that they can hold for 6 months but that's also not possible.
I would appreciate if anyone can suggest workaround
by Ace Contributor
Solution
Re: unlocking iphone 11 pro
Hi @gogolino
Welcome to the EE Community,
unfortunately your not able to unlock the device until you have had it for 6 months as per the terms and conditions of your contract.
Thanks,
David.
by Ace Contributor
Solution
Hi @gogolino
Thanks,
David.
