by srobo2
osprey abroad
Hi, I use a 4GEE sim card in an EE router for my home internet. My tariff includes roaming in EU countries so I have bought a small travel router: an EE Osprey (the yellow and black one) for use when we are on holidays in EU countries.
Do I need to have the SIM card or the Osprey device 'unlocked' to use them abroad or will it be just like a mobile phone that just works when away?
12 REPLIES 12
Re: osprey abroad
@srobo2  You don’t need it unlocked you just need to make sure roaming is enabled on your account.  Call customer services to do this.
Re: osprey abroad
You don't need the Osprey unlocking if you're just running it on an EE SIM. EE Devices only need unlocking to run on non-EE SIMs.
As you are on PAYG roaming is already enabled for you.
by srobo2
Re: osprey abroad
Thanks, although I am on contract, not PAYG. You think it will still work abroad without having to contact customer services?
Re: osprey abroad
Sorry, my mistaken assumption :(.
On contract you do need roaming enabled. Text ROAMING to 150 to check if it is.
Re: osprey abroad
@srobo2  Please read what I originally put.  Seeing as you can not text from a router.
 If your Sim card fits into a mobile phone then you could use text service to enable roaming on your contract
text Roaming to 150
Re: osprey abroad
@Chris_B: The Osprey does SMS as does most MBB routers.
Re: osprey abroad
@XRaySpeX  Does it ??
@srobo2  Ok what he said.
Just to add add you can only use up to 15GB of data a month if your contract allowance has more than this when roaming.
Re: osprey abroad
@Chris_B: Yes, it does. Explore yours a bit more carefully.
To read text messages sent to   your 4GEE WiFi number,  click here and log in.
Re: osprey abroad
@XRaySpeX  That’s very  presumptuous of you to assume that I even have one.
Just to be clear I don’t own and never have owned in fact I don’t believe I’ve  even touched one.
Re: osprey abroad
@Chris_B: Sorry, I thought you had 1.
Re: osprey abroad
@XRaySpeX! Why get one when you can tether from a phone if needs be.
EE Employee
Re: osprey abroad
Hi @srobo2 and welcome to the community.
Please follow the wonderful advice given by @XRaySpeX and login to your main admin page by popping over to 192.168.1.1.
Hope this helps,
Lee
