by Charles150290
my rook ee will not factory reset
I have forgotten my pattern haven't used it for some time now but unfortunately my main phone is now water damaged so I need to use this temporary.
I have done volume up and power button but factory reset keeps failing!?
I do manage to remember it yesterday but when I tried to change patern took to long to remember again and phone went to screen lock so yeah I'm back to square one i have properly attempted this now over 1000 times!.. Should I give up or could you help please?
6 REPLIES 6
Re: my rook ee will not factory reset
@Charles150290  Unfortunately unless you remember the pattern there is no work around it’s a security thing and it’s doing it job.  You can not  factory reset it until you get into the device.
by Brilliant Contributor
@Chris_B I don't know about Apple but you don't need to be in the device to factory reset.
Volume up home and power button should work.
If it isn't @Charles150290 have you tried connecting to your pc and doing it that way
Hi @Charles150290
Welcome to the community.
Were you given the option to unlock with a security question rather than the key sequence?
Does it tell you if your have X amount of tries left?
by Charles150290
No it hasnt just patterns after patterns.. There is no message stateing x mount left. I have tried volume button and power key to factory resat and it just keeps failing?
Thanks for confirming, @Charles150290
I've sent you a private message for some more information.
Please take a look and get back to me.
Hi @Charles150290
Try turning the device off before you go into recovery.
Thanks,
