by geoffbuster
ive change my phone and the sim needs a pin to unlock network
my pin 111 wont work to unlock network
by Ace Contributor
Re: ive change my phone and the sim needs a pin to unlock network
Hi @geoffbuster
it’s usually 4 digits, not 3 to unlock.  Have you tried this? If you are still having issues, it’s best to call EE customer services for assistance to help you with this.
Is the phone compatible with your chosen network?  ie it’s not locked to a certain network that’s different to your sim?
Good Afternoon @geoffbuster
Welcome to the community.
Is the phone locked to EE?
What SIM card are you using?
If the code you have received is not working, I would recommend getting back in touch with our mobile care team.
Speak soon, Katie 🙂
by Profile closed
Not applicable
Hi, @geoffbuster,
I think the pin no you require is: ( 1111 )
This is how I unlocked my Sim
Regards
mAh8v
What are you actually trying to do? Are you wanting to unlock your phone so it can be can be used on any network?
Which network's SIM are you trying to use in the phone?
Where did you get this phone from?
