by coloquil1 Contributor
how do I unlock my buzzard 2
i have been in touch with ee tech dept and they sent me an email to unlock my buzzard 2 but it does not worki have an sky sim but cannot get to the website 192.168.1.1 so how can i get this unlocked please
11 REPLIES 11
Re: how do I unlock my buzzard 2
@coloquil1  With your phone/tablet connected to the buzzard go to that IP address.
by Profile closed
Not applicable
Hello @coloquil1 have you requested the unlock and did the email contain the unlock code for your device?
Here is a link containing more information on unlocking a device through EE:
https://community.ee.co.uk/t5/Unlocking-your-device/Unlocking-your-EE-mobile-phone-or-device/td-p/55...
hi,thank you for replying i have the imei number and the unlocking code but when i put the sky sim in the buzzard it does not go to the website 192.168.1.1 and when i plug my android phone into the dongle and put in this address manually it still does not go to the site?
by Profile closed
Not applicable
Hello @coloquil1 what device are you using to try and connect to the Buzzard? Does it connect via WiFi successfully? 🙂
hi tom,
            when with ee i can get the wifi succesfully i was told to connect the sky sim i wish to use and it should display network is locked but of course there is no display on the buzzard so i have tried to go to the address 192.168.1.1 and it just wontr go to this adress i have tried everthing i can think of but nothing works i can use my smart phone and get a adress that says admin code and password but dont know what this is must admit getting a bit annoyed at mo
Hi @coloquil1,
Welcome to the EE Community.
We are aware of some issues with the unlocking of Buzzard devices.
We are working with the manufacturer on a fix and hope to resolve the issue soon.
be grateful of a time limit for when there is a soloution james.
 keith
Hi @coloquil1,
I'm afraid I don't have a estimated date at the moment.
We'll let you know as soon as we have an update.
Hi @coloquil1,
This issue has now been fixed.
Please get in touch with customer services for a new unlocking code.
hi James,
       IT IS NOT FIXED BUT I AM GOING TO BUY AN UNLOCKED ONE AND EE HAVE KINDLY SAID THEY WILL SEND ME A CHEQUE.SO I SUPPOSE IT IS FIXED IN A WAY.
THANK YOU FOR YOUR HELP
    KEITH
No problem @coloquil1
