by Tidy-12 Investigator
forgot pin number to unlock phone
i have forgottenmy pin number to open phone to make calls lg 130
Solution
Re: forgot pin number to unlock phone
You might have to hard reset your phone then, @Tidy-12.
This will delete everything within your phone. If you've backed up your information before, you'll be able to restore it all back onto the phone:
  1. Turn the power off.
  2. Press and hold the Power/Lock key + Volume Down key on the back of the phone.
  3. Release the Power/Lock Key only when the LG logo is displayed, then immediately press and hold the Power/Lock Key again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key to continue or either of the Volume Keys to cancel.
  6. Press the Power/Lock Key once more to confirm or either of the Volume Keys to cancel.
8 REPLIES 8
Hi @Tidy-12
Welcome to the community. 🙂
Is it the SIM PIN that you have forgotten or your keypad lock?
The default SIM PIN is 1111.
Pin to unlock keypad
Could you confirm which model your phone is, @Tidy-12?
Is it the LG KG-130?
Lgk8
Thanks @Tidy-12
When you get to the point where it's asking for your code, tap your power key twice. Does it give you an option for 'forgot password'?
No
Solution
Thank you
