by Profile closed
Not applicable
Unlocking an old phone
Want to unlock a previous phone using the form, but the form requires the phone number of that phone and I am using that number on my new phone as i transferred the sims, if i put in the number and the imei of the old phone and request to unlock, will it affect my new phone and that number at all?
by Brilliant Contributor
Solution
Re: Unlocking an old phone
No as long as you put the IMEI of the old phne in it won't effect your new phone at all.
Solution
by Ace Contributor
HI, @Profile closed
No it will not effect your new phone.
But made sure you put your old phone imei number to avoid any hassle.
Hi @Profile closed
Thank you for coming to community 🙂
Please follow the advice of @BrendonH and use the IMEI.
Thank you also for helping with this @tahirmian
Richard
