by spinstorm Valued Contributor
Valued Contributor
Unlock iPad Pro 2018 - EE unlock site says it isn't locked but it is?
Hoping for an answer here.
I am trying to submit my iPad Pro 12.9" 2018  on contract with EE to unlock it as I am going to the US and would like to use it there.
When I try and submit the form to unlock it initally says the IMEI is locked; then it doesn't recognise my mobile data phone number - then it asks me for the IMEI again and this time it says it isn't locked. I know it is locked as I tried another SIM card...
What is going on? I should be able to submit an unlock request!?
by Ace Contributor
Re: Unlock iPad Pro 2018 - EE unlock site says it isn't locked but it is?
Hi @spinstorm
Welcome to the EE Community,
If the iPad is under 6 months old EE will not unlock it.
if it is over 6 months old you can fill in the webform here
https://myaccount.ee.co.uk/app/device-unlock
Failing that I would give 150 a call and ask to speak with the unlocking team.
@spinstorm: Did you buy this device yourself new direct from EE or is it 2nd-hand? The process & costs are different.
Valued Contributor
It was bought on contract from EE. I understand it is less than 6 months old.
However, the unlock process should still recognise my IMEI/Number as locked.
I would expect to be told it isn’t long enough or to get an email saying that.
But the site doesn’t recognise the number or IMEI as locked.
Hi @spinstorm
Could you try it again once you've had it for 6 months? It should let you know that it's locked and then you can request to unlock it.
