by plremcconn Investigator
Unlock going abroad and reconnecting back
My daughter is going to USA for a month and i will need to unlock her Iphone7 to accept a different sim. ( The rates from EE are completely prohibitive for any  use at all)
She is on PAYG and has been for several years building up significant boosts.
My question if i unlock her iphone7 and use the device with a different sim whislt abroad
Can i unlock that device when she comes back and insert her old sim that i will keep ticking along .
Solution
Re: Unlock going abroad and reconnecting back
If you bought an iPhone directly from EE after 01/09/15 it should have been auto unlocked after 18 months. Using the form below will also confirm this.
You can just apply for unlocking using the Unlocking your device form as the PAYG option and giving the mobile number that it originally came with. It should be free.
Once it is unlocked it will work for ever with any SIM. So she doesn't need to do anything on return.
Solution
by Ace Contributor
@XRaySpeX  is correct. @plremcconn You can simply swap sims as you please when unlocked .
Thanks I've submitted the request to unlock and we will see how it goes from there.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
