by mikesfc Investigator
Transfering my number
Been waiting 30+hours for my number to be transferred.
Solution
Re: Transfering my number
Hello there @mikesfc.
Welcome to the community.
How did you request to transfer your number?
Also have you received any texts from us at all?
Thanks, Leanne 🙂
15 REPLIES 15
Solution
Thanks, Leanne 🙂
As soon as I posted about the waiting for transfer of number 5 minutes later it had been done
Sent from Mail for Windows 10
Good morning @mikesfc
You must have triggered something by posting about it 🙂
Brilliant news and thank you for sharing with us.
I shall make sure @Leanne_T knows the good news to!
Richard
by Claireisherwood Investigator
Hi I have been waiting for my number to be transferred over, I received a text message yesterday saying it would be done on the 7/4/2017 but it has not been done yet. The number I want to transfer has been deactivated since 12 yesterday as well.
Hello there @Claireisherwood.
What device are you using?
Have you had any text to the new device at all?
Thanks 🙂
Hi I am using a iPhone 7, I have received the text message to my new phone. My old number was on o2.
Great thanks @Claireisherwood
If anyone calls your 02 number what happens?
Is the temporary number showing in your settings?
Go to Settings > Phone > Number will be shown.
Speak soon 🙂
If you ring my o2 number it won't connect and yes my temporary number is still showing under settings. Thank you
Thanks @Claireisherwood
In this case we will need to check the number transfer for you.
If you tap the get in touch page here and select EE this has an option for chat.
They will be able to have a look into this for you.
Let me know how you get on 🙂
by Profile closed
Not applicable
@Claireisherwood
To update your number in the settings, you need to do the following:
1) Turn off iMessage by going to Settings>Messages then turn of iMessage.
2) Turn off FaceTime by going to Settings>FaceTime then turn off FaceTime.
3) Go to Settings>Phone>My Number abnd update your number in there.
4) Completely turn off your iPhone by pressing the power button until you see the 'Slide to power off' message, do that, wait a few minutes and then turn it back on again.
5) Turn on iMessage (as above).
6) Turn on FaceTime (as above).
That should reset everything.
It won't load up the live chat option?
Hi there @Claireisherwood,
Did you try the steps @Profile closed advised above?
If chat is not loading please give us a call 🙂
Thanks!
I am still waiting for my phone number to be transferred, I've rang and spoke to someone who said it was done and told me to update the settings which I did and nothing happened, I spoke to someone on live chat who told me I had to back everything and reinstall from iTunes and that this would definitely work but it hasn't!!!help!!!
I am still waiting for my number to be transferred! I rang and spoke to someone who said it was done and for me to update the settings which I did and it didn't work, I also spoke to someone on live chat who told me to back everything up and reinstall from iTunes which I did and it still hasn't worked!!!!help!!!
Good morning @Clairesherwood
Thanks for getting back to us 🙂
Just checking in on this with you to see if the number is now updated?
Fingers crossed it's all fixed and sorted out.
Cheers
Richard
Recent solutions
