by ShohanSen Contributor
Re: Unlocking your mobile phone or device – The EE quick guide
Hi!
I have an iPhone 5S that I'm looking to sell now that I've upgraded phones. I don't have an alternate SIM card to check whether the phone is unlocked, but am I correct in assuming that if the phone was bought from an alternative vendor, the phone is likely to be unlocked anyway?
Thanks!
20 REPLIES 20
Is iPhone Bought from 3rd-Party Vendor Unlocked?
@ShohanSen: No, you can't assume that. It could have been sold SIM-Free which means it locks to the 1st SIM activated in it. This is typical of CPW iPhones.
Hi @ShohanSen,
Welcome to the EE Community.
If you are out of contract, you can unlock your phone for free via the online unlocking form.
Hope this helps.
Thanks!
I am out of contract and filled in the form, but the device was found via the IMEI number rather than a phone number because the phone currently does not have a SIM card in it. Would this be a viable process for the phone to unlock?
Thanks again!
Hi @ShohanSen,
Yes, as long as it's the correct IMEI number that's fine.
Brilliant! Thanks for your help!
Yes, that's correct for a phone bought directly from EE, but if it was bought elsewhere EE might not recognise it.
In which case you will need to call Customer Services on 0800 956 6000 (option 2, option 4) to put you in touch with the Unlocking Team to request an Unlock Code. You will be asked for your email addy. They may take payment (of £8.99) from any valid UK bank card.
Once the process has been started you will receive an email from the Unlocking Team to process the unlock. It can take up to 10 days to complete the unlock.
No problem @ShohanSen Smiley Happy
Thank you! EE were able to unlock the phone via only the IMEI number Smiley Happy
Much appreciated
Brilliant news @ShohanSen
Richard
Hello,
I sent a request to unlock an old iPhone with the IMEI number and I received a text on my current number to notify me that the phone had been unlocked. However, when I placed a non-EE sim card into the iPhone, I received a message saying the SIM card was not supported.
I wanted to contact EE to check that the unlock had been successfully completed (is this the best way to check the unlock has been carried out?) but after calling 150, I was a little unsure on what option to select. I selected "1" for mobile phones, but what should I select after that?
Many thanks for your help!
EE Employee
Hi and welcome to the community @ShohanSen,
You do need to complete the unlocking using a compatible SIM, are you in the UK?
Many thanks,
Lee
@ShohanSen  What model iPhone is it ?
Is the SIM card your using my activated?  You can not use a unactivated SIM card in a different network locked device.
Ah! That might be it! The new SIM card isn't activated yet. I'll activate the SIM card card and let you both know if the problem is solved Smiley Happy
EE Employee
I used two SIM cards, both of which I am pretty sure are activated. On both occasions, the SIMs were "not supported". I am 90% sure at least one of the SIM cards were activated because I believe I did so earlier, but cannot check for sure as I have no unlocked devices other than the iPhone I am trying to unlock currently.
Therefore, my original question stands; what is the best way to contact EE to double check that the unlock request was processed correctly.
I really appreciate the prompt help you have provided me thus far Smiley Happy
EE Employee
Hi @ShohanSen
Which network SIM cards have you tried?
Many thanks,
Lee
I tried O2 (which, when 'googled', told me that their SIM cards come readily activated) and Lebara mobile (which I believe I activated earlier, but cannot be 100% sure) SIM cards.
EE Employee
Hi @ShohanSen,
Please see @XRaySpeX 's post on contacting the unlocking team.
Many thanks,
Lee
Thanks guys!
I was able to contact the team and now all the devices I wanted unlocked, are unlocked!
