by jimpatston
Need to unlock an original Nokia 3310 from Orange
I need to be able to put an EE SIM card into my old 3310. I can’t find an online code finder that actually works.
Re: Need to unlock an original Nokia 3310 from Orange
Did you buy this device yourself new direct from EE/Orange or is it 2nd-hand? The process & costs are different.
@jimpatston  Do you remember the number that was used in this device?  If you don’t your going to have to call customer services and it will cost you £.8.99 and it will take up to 10 days to process.   You need to call also if the device is 2nd hand and you’ll be charged the same amount.
If you do remember the number you can use THIS and it’s free.
if your reality desperate to unlock it now I highly recommend looking on eBay
EE Employee
Hi @jimpatston and welcome to the community.
Hopefully, the wonderful advice above has helped with your query.
Many thanks,
Lee
